Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using the Siebel Data Mapper > Creating Data Maps >
Validating the Data Map
Once you have created your data map, you need to validate your data map. To validate your data map
- From the application-level menu, choose View > Site Map > Integration Administration > Data Maps.
- Select your data map.
- Click Validate to validate your data map.
- Take the necessary actions to fix the problems with your map or the associated integration objects.
