Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > Siebel Message Objects and Methods > Primary Integration Component ObjectsA primary integration component represents the integration component contained within an integration object instance. It has a name and contains records with data from actual integration components. Each record may have fields and subordinate integration components. The following primary integration component objects are provided: |
Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
