Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts >
MIME Message Objects and Methods
Siebel eAI represents MIME documents using a property set format. This is the format used by the EAI MIME Doc Converter Business Service. The objects and methods described here provide access to this property set format, and are intended for use in conjunction with transforming pieces of the MIME message to and from Siebel Integration Messages.
NOTE:  The EAI MIME Hierarchy Converter Business Service is the preferred method of converting between the property set representation Siebel Messages.
The following MIME message objects are provided:
  • CSSEAIMimeMsgIn
  • CSSEAIMimeMsgOut
