Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > XML Property Set FunctionsSiebel eAI represents XML documents using the property set format. While Siebel eAI does not always require using the property set format, this representation is used by EAI Business Services such as the EAI XML Converter. The functions described in this section provide a simple interface for manipulating XML documents using the property set format. |
Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
