XML Reference: Siebel eBusiness Application Integration Volume V > Using XML Files > Inserting File Attachments Using XMLThere may be times when you have an attachment that you want to insert into the Siebel Database, such as an image file in JPEG format. This could be a customer's picture, a site picture, an item or part image, a text document, and so on. For integration with external systems using File Attachments, refer to the chapter "Siebel eAI and File Attachments" in Integration Platform Technologies: Siebel eBusiness Application Integration Volume II. For integration between Siebel instances, the support for attachments is built into the Siebel Adapter and the EAI XML Converter. The integration between Siebel instances can occur when generating or reading XML, which is further defined in the next section.
XML Reference: Siebel eBusiness Application Integration Volume V |
