XML Reference: Siebel eBusiness Application Integration Volume V > XML Representation of Property Sets >
Properly Formatted Property Sets
Property sets are used internally to represent Siebel eAI data. A property set is a logical memory structure that is used to pass the data between business services.
To benefit from using the XML Converter, be sure that any code you use, such as eScript or Siebel VB, correctly represents property sets within Siebel applications for the XML Converter Business Service. This includes necessary arguments and values. An example of such code is:
Set Inputs = TheApplication.NewPropertySet
REM Fill in Siebel Message Header
Inputs.SetType "SiebelMessage"
Inputs.SetProperty "MessageId", ""
Inputs.SetProperty "MessageType", "Integration Object"
Inputs.SetProperty "IntObjectName", "Sample Account"
Set svc = theApplication.GetService("EAI XML Converter")
Set XMLInputs = theApplication.NewPropertySet
Set XMLOutputs = theApplication.NewPropertySet
XMLInputs.AddChild Inputs
svc.InvokeMethod "PropSetToXML", XMLInputs, XMLOutputs
