XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Scenarios > Scenario 1: Integration Using Siebel XML >
Running the Integration
In this scenario, assume that either an external application has generated Siebel XML that requires no translation or Siebel XML is XML that conforms to the Siebel XSD or DTD. At runtime, the Siebel application:
- Calls the EAI XML Adapter.
- Calls the EAI XML Converter to convert the incoming XML to a Siebel message.
- Calls the EAI Siebel Adapter and updates the Siebel Database with the new information just received from the incoming (external) XML document.
