XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the DTD Wizard > How the DTD Wizard Creates XML Integration Objects > Element's #PCDATAIf the element is mapped to an integration component, then its #PCDATA is mapped to a component field |
XML Reference: Siebel eBusiness Application Integration Volume V |
