Siebel Enterprise Integration Manager Administration Guide > Deleting Data > Editing the Configuration File for Delete ProcessingThis section describes the header and process sections that you need in the EIM configuration file to properly configure EIM for a delete process. It also discusses the parameters in the configuration file that must be adjusted for the delete process. For general information on the EIM configuration file, see EIM Configuration File. Before delete processing begins, you must change the configuration file to support this function. Such changes include: |
Siebel Enterprise Integration Manager Administration Guide |
