Importing data into Siebel base tables is a multistep process that requires significant effort. You must first load data from an external database into the EIM tables. Subsequently, you need to run an EIM process to read the data in these EIM tables and import them into the appropriate Siebel base tables.
This chapter is organized into the following sections:
Siebel Enterprise Integration Manager Administration Guide
