Siebel Enterprise Integration Manager Administration Guide > Merging Data > Editing the Configuration File for Merge Processing > Enabling Transaction Logging for Merge ProcessingTo enable transaction logging for an EIM merge process, set the following parameters in the .IFB file so the EIM merge process runs in ongoing (row-by-row) mode: For information on the LOG TRANSACTIONS parameter, see Optional Keywords for Process Parameters. For information on the SET BASED LOGGING parameter, see Process Section Parameters Used for Merges. |
Siebel Enterprise Integration Manager Administration Guide |
