Siebel Enterprise Integration Manager Administration Guide > Siebel Enterprise Integration Manager: An Overview > EIM Functions >
Merge Data in Siebel Base Tables
In response to such external events as corporate mergers, you can merge two or more database rows into a single row. For example, you might merge the Frame, Inc. account information into the Adobe Corp. account. Refer to Merging Data for a detailed discussion of the merge function.
