Siebel Enterprise Integration Manager Administration Guide > Running EIM > Optimizing EIM Performance >
Parameter Settings Optimization for EIM
This section discusses ways that you can optimize EIM performance through parameter settings.
USING SYNONYMS Parameter for Optimizing EIM
Ignore account synonyms. Set the USING SYNONYMS parameter to FALSE in the .IFB file to indicate that account synonyms can be ignored during processing. This logical operator indicates to EIM that account synonyms do not require processing during import, thus reducing the amount of processing. Do not set the USING SYNONYMS parameter to FALSE if you plan to use multiple addresses for accounts. Otherwise, EIM will not attach addresses to the appropriate accounts. You can use EIM_ACCOUNT to import accounts with multiple addresses and then specify the primary address for an account by setting ACC_PR_ADDR to Y.
Trace Flag Settings for Optimizing EIM
Generate a task log to identify slow-running steps and queries by using Trace Flags. To use Trace Flags, set Error Flags=1, Trace Flags=1, and SQL Trace Flags=8. Rerun the batch and use the resulting task log to determine which steps and queries are running especially slowly. For additional information on trace flag settings, see Trace Flag Settings.
