Siebel Enterprise Integration Manager Administration Guide > Running EIM >
Preparing to Run an EIM Process
You can run an EIM process (import, export, delete, or merge) once you have:
  • Identified the data for EIM processing
  • Prepared the related EIM tables
  • Modified the EIM configuration file accordingly
You can start an EIM process by running a server task for the Enterprise Integration Manager component. You can run the server task using either the GUI or the command-line interface. For more information on running server tasks, see Siebel System Administration Guide.
