Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables >
EIM Table and Column Mappings
EIM uses EIM table mappings to map columns from EIM tables to Siebel base tables. Siebel predefined EIM mappings are fixed and cannot be remapped. Using Siebel Tools, you can:
  • View EIM table mappings to Siebel base tables
  • View interface column mappings to Siebel base table columns
  • View Siebel base table mappings to EIM tables
  • Print EIM table reports
Some base tables may not be mapped to a corresponding EIM table. In such cases, use Siebel VB to load data into these base tables and inform Siebel Technical Services regarding the missing mapping. EIM does not interfere with Siebel VB code because Siebel VB works at the business object layer, and EIM works at the data object layer. You can also use the EIM Table Mapping Wizard to add missing mappings. For more information, see Configuring Siebel eBusiness Applications.
For information on using Siebel VB, see Siebel VB Language Reference.
