Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples >
Visibility of Fields: Example of Importing Accounts
This example is specific to Siebel Industry Applications.
To view all accounts, the data must be inserted into the S_PARTY, S_ACCNT_POSTN, S_ORG_EXT, and S_ORG_BU tables, as well as other relevant tables.
NOTE:  S_ORG_BU is a table that is new in Siebel 7. This table must be populated for visibility in the All Accounts view.
To insert the data into the required tables, you can use the EIM_ACCNT_CUT and EIM_ACCOUNT interface tables. Make sure the values in the OU_NUM and MASTER_OU_ID columns of the S_ORG_EXT base table are populated.
In Siebel Industry Solutions (SIS) version 7.0.x and Siebel Industry Applications (SIA) version 7.5.x, there is no mapping in the EIM_ACCNT_CUT interface table to the S_ORG_BU table. However, the EIM_ACCOUNT and EIM_ORG_BU interface tables are mapped to S_ORG_BU. You can use EIM_ACCOUNT and EIM_ORG_BU to populate S_ORG_BU.
In SIS and SIA, MASTER_OU_ID in S_ORG_EXT must be populated for visibility in any of the Accounts views. If S_ORG_EXT.MASTER_OU_ID is not populated, the imported accounts will be visible only in the Data Administration >Accounts/Orgs view. The imported accounts will not be visible in the Data Administration >Accounts view or any other view including My Accounts, All Accounts, and All Accounts Across Organizations.
NOTE:  When loading account addresses, make sure to set an explicit primary. The default setting is implicit, which means that primaries are not set until a record is retrieved in the application. This can cause queries, such as on the State field, to return incomplete or inconsistent data. For more information, see About Explicit Primary Mappings.
The sample .IFB file that follows can be used for importing accounts. The account visibility depends on S_ORG_BU to resolve the organization and S_ACCT_POSTN for the position.
[Siebel Interface Manager]
USER NAME = "SADMIN"
PASSWORD = "SADMIN"
PROCESS = Import Account
[Import Account]
TYPE = IMPORT
BATCH = 555
TABLE = EIM_ACCOUNT
ONLY BASE TABLES = S_PARTY, S_ACCNT_POSTN, S_ORG_EXT, S_ORG_BU
DEFAULT COLUMN = ACCNT_FLG, "Y"
DEFAULT COLUMN = ACTIVE_FLG, "Y"
DEFAULT COLUMN = BUYING_GROUP_FLG, "N"
DEFAULT COLUMN = CG_DEDN_AUTH_FLG, "Y"
DEFAULT COLUMN = CG_SVP_A_LOCK_FLG, "N"
DEFAULT COLUMN = CG_SVP_LOCK_FLG, "N"
DEFAULT COLUMN = CG_SVP_SKIP_FLG, "N"
DEFAULT COLUMN = CL_SITE_FLG, "N"
DEFAULT COLUMN = DISA_CLEANSE_FLG, "N"
DEFAULT COLUMN = EVT_LOC_FLG, "N"
DEFAULT COLUMN = FCST_ORG_FLG, "N"
DEFAULT COLUMN = FUND_ELIG_FLG, "N"
DEFAULT COLUMN = INCL_FLG, "N"
DEFAULT COLUMN = INT_ORG_FLG, "N"
DEFAULT COLUMN = PLAN_GROUP_FLG, "N"
DEFAULT COLUMN = PROSPECT_FLG, "N"
DEFAULT COLUMN = PRTNR_FLG, "N"
DEFAULT COLUMN = PRTNR_PUBLISH_FLG, "N"
DEFAULT COLUMN = RPLCD_WTH_CMPT_FLG, "N"
DEFAULT COLUMN = SKIP_PO_CRDCHK_FLG, "N
