Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples >
Example of Updating a Table in a One-to-One Relationship with Its Parent
To update a table that has a one-to-one relationship with its parent table, make sure that the EIM table has only one record matching the user key of the target table.
For example, to update column values in S_ORG_EXT_X using EIM_ACCNT_DTL, there can be only one record in EIM_ACCNT_DTL that matches the user key of the S_ORG_EXT_X table. If more than one record with the same user key is inserted into this EIM table, then EIM might select the wrong record for update, and update IF_ROW_STAT with DUP_RECORD_EXISTS for the rest of the records.
