Siebel Energy Guide > Technical Reference for the Price Comparison Feature > SIS OM Pricing Calculator Business Service >
Convert PC Input to PC Quote Method
This method is part of SIS OM Pricing Calculator Business Service.
The answers from a SmartScript session are taken as the Pricing Calculator input and are converted into a Competitor Quote. Multiple quotes are created as appropriate, based on the SmartScript answers.
Arguments
PCMultiQuotes
[out] List of SIS OM Quote integration object instances that are used to store the utility billing information provided by a prospective customer. (Required)
Opportunity
[in] Name of the opportunity object under which the generated PC Comparison quotes will be stored. (Required)
OpportunityId
[in] ID of the opportunity object under which the generated PC Comparison quotes will be stored. (Required)
RunId
[in] RunId of the SmartScript session where the answers are stored. This typically will be a process property that is set internally when the SmartScript session is finished. (Required)
Returns
PCMultiQuotes
See Also
SIS OM PC Comparison Workflow.
Siebel Energy Guide
