Siebel Energy Guide > Technical Reference for the Price Comparison Feature > SIS OM Pricing Calculator Business Service >
Bill Decomposer Method
This method is part of SIS OM Pricing Calculator Business Service.
This method decomposes a utility bill provided by a prospective customer into the usage breakdown. The calculation is based on a number of billing parameters derived from the information on the utility bill.
Arguments
PCMultiQuotes
[in/out] List of SIS OM Quote integration object instances that are used to store the utility bill information provided by a prospective customer. The usage breakdown is also written back into this quote structure as output. (Required)
Returns
List of SIS OM Quote integration object instances that contain the usage breakdown.
Remarks
The usage breakdown is represented in a quote integration object as the Quantity field of a usage sub-line item with the Usage Type attribute set to a specific value (for example, Threshold, Peak, Off Peak).
See Also
SIS OM PC Comparison Workflow.
Siebel Energy Guide
