Siebel Energy Guide > Oil Well Management >
Adding New Leases
The oil field services administrator uses the well screen to set up leases, wells, and equipment. Each lease contains multiple wells.
When you have a new customer or when an existing customer calls with work on a lease that the oil field services company has not worked on before, the oil field service administrator works with the customer to enter information about the lease.
You should enter information about leases before you enter information about the wells and equipment at that lease.
To add a new lease
  1. Navigate to the Wells screen.
  2. Add a new record to the Well list.
  3. In the Completion Type/Product field, select Lease.
  4. Complete the other necessary fields in the Well list and the More Info form, as described in Fields of the Well List.
Siebel Energy Guide
