Siebel Energy Guide > Oil Well Management >
Adding or Modifying a Well Address
When you create a new well, you enter the well address, including its county, state, latitude, longitude, and directions to the well.
To enter this address or to modify it, you must click the select button in the County field for the well to display the Pick Well Address dialog box. Well address fields can only be entered or modified in this dialog box. Elsewhere, they are read-only.
To add or modify a well address
  1. Navigate to the Wells screen.
  2. In the Well list, in the Well County field of the well whose address you are entering, click the select button.
  3. In the Pick Well Address dialog box, add or modify information about the wells county, state, latitude, longitude, and directions to the well, and click Close.
Siebel Energy Guide
