Siebel Energy Guide > Premises in Siebel Energy >
Adding Infrastructure Information in Siebel Energy (End User)
End users can create a record containing infrastructure information that is associated with a premise through an account. To add infrastructure information to a premise
- Navigate to the Premises screen.
- In the Premises list, click the name of a premise.
- Click the Infrastructure view tab.
Two Infrastructure lists appear. The upper list displays accounts and the lower list displays infrastructure.
- In the upper list, select an account.
- In the lower Infrastructure list, add a record and complete the necessary fields.
Some fields are described in the following table.
Attribute |
An attribute of the infrastructure item, such as Substation ID or Transformer Type. Changes dynamically according to the value selected in Service Type. |
Owner |
Customer or account that owns the infrastructure item. |
Value |
Information about the data in the Attribute field. For example, if the Attribute is Voltage at Meter, a typical Value would be 240 volts. |
