Siebel Energy Guide > Premises in Siebel Energy >
Registering a Premise Hookup in Siebel Energy (End User)
Premises can be associated with one or more service points. If your application is configured to allow you to manage meters separately from service points, you can associate a meter with a premise through a service point. Otherwise, you can only associate a meter point (the meter) with a premise. To add a service point and associate it with a premise
- Navigate to Administration - Data > Premises.
- In the All Premises list, select a premise.
- Click the Service Points view tab.
- In the Service Points list, add a record.
The Service Points dialog box appears with a list of service points that are not associated with any premises.
- In the dialog box, select an existing service point or click New to create a new service point.
- In the Service Points list, complete the necessary fields.
Some fields are described in the following table.
Location |
Description of the location of the service point. |
Product |
Associate a product with this service point. Only products in which the value in the product's Type field is Service Point and Service Type is not null are available for selection. |
Removal Date |
Date on which the service point is removed from the premise. |
To associate a meter with a service point
- Click the Meter Location view tab.
- In the Meter Location list, add a record and complete the necessary fields.
Meter Id |
Identifier generated automatically when a meter record is created in Siebel Energy. |
Start Date |
Date the meter is associated with the service point. |
