Siebel Events Management Guide > Registering for an Event >
Tracking Guests of Attendees
Certain types of events permit attendees to bring guests. You can track guests for each registered attendee.
To specify that an attendee is a guest of another attendee
  1. Navigate to the Site Map > Events > Event > Attendees view.
  2. In the Attendees list, select the attendee record for the guest you want to specify as a guest of another attendee.
  3. In the Guest Of field, click the multiple select button to select the primary attendee.
  4. Select the primary attendee, and then click OK.
    NOTE:  Only registered attendees appear for selection in the Guest Of field.
