Siebel Field Service Guide > Business Service Methods Reference for Field Service > Replenishment > GenerateOrder MethodGenerateOrder is used to select source and target inventories when restocking is needed. The method then generates the orders required to obtain materials from an external provider, an internal inventory site, or an internal manufacturing facility. UsageThe input parameters are called if invoking from code or from a component request. See Parameters for the Replenishment Engine for more information about these parameters. Additional DetailsBy default, the Replenishment Engine is run as a server component and not as a business service. |
Siebel Field Service Guide |
