Siebel Field Service Guide > Service Inventory >
Tracking Inventory
Follow these procedures to verify inventory.
To verify inventory status using the Inventory screen
  1. Navigate to the Inventory screen.
  2. Drill down on a selected inventory location, and then click the Product Inventory view tab.
  3. Select a product.
    The Inventory Level subview shows the inventory status for all products at the selected location.
To verify inventory status using the Part Browser
  1. Navigate to the Part Browser screen.
  2. Select a product.
    The Inventory Level subview shows the inventory status for the selected product.
To generate inventory status reports
  2. Select an inventory location, and then choose Reports > Product List by Location or Products Below Minimum Level by Location.
To view cycle counting parameters for a selected location
  2. Drill down on a selected inventory location.
    Cycle counting parameters appear on the More Info tab.
To view all inventory transactions
  • Navigate to the Inventory Transactions screen.
