Siebel Field Service Guide > Setting Up and Using Scheduling > Reloading the ABS and Optimizer Caches > Coalescing the Appointment Booking SystemThis task is a step in Process of Setting Up Scheduling. You can improve appointment schedules by coalescing the ABS; time gaps are removed from between booked appointments. This asynchronous request is carried out for one service region at a time. |
Siebel Field Service Guide |
