Siebel Forecasting Guide > Forecasting User Properties >
Forecast 2000 - Forecast Series Date User Properties
Table 15 describes the user properties associated with the business component: Forecast 2000 - Forecast Series Date.
Table 15.  Forecast 2000 - Forecast Series Date
User Property
Value
Comments
Auto-Set Start/End Dates
N
If enabled, when the end user creates a new record and sets the Forecast Date field, Start Date automatically defaults to the period that the Forecast Date falls in.
If the end user is copying a record, the End Date defaults so that the difference (number of periods) between the source record's Start Date and End Date is maintained.
Series Subst Var: FCST_DATE_LOWER_BOUND
Date - Lower Bound
Special variable available for use in Auto, Assoc, and Date Range search specs.
Using this variable, administrators can access the lower bound of the Forecast Series Date record, for example the earliest of {History View Date, History Edit Date, Start Date}, some of which can be null.
Series Subst Var: FCST_EFFECTIVE_DATE
Forecast Date
Using this variable, administrators can access the Forecast Date.
Series Subst Var: FCST_END_DATE
End Date
Special variable available for use in Auto, Assoc, Date Range search specs.
Through this variable, administrators can access the End Date.
Series Subst Var: FCST_HISTE_START_DATE
History Edit Date
Using this variable, administrators can access the History Edit Date, which can be null. The History Edit Date defaults to History View if defined, otherwise it defaults to Start Date.
Series Subst Var: FCST_HISTV_START_DATE
History View Date
Using this variable, administrators can access the History View Date, which can be null. The History View Date defaults to the earlier of {History Edit, Start}.
Series Subst Var: FCST_START_DATE
Start Date
Using this variable, administrators can access the Start Date, which cannot be null.
