Fundamentals > Common Record Tasks >
Deleting Records
You can delete a record by using the Delete button, the menu button in a list or form, the application-level menu, or the appropriate keyboard shortcut. For more information about keyboard shortcuts, see Using Keyboard Shortcuts.
To delete a record using the Delete button
  1. Select the record you want to delete.
    In a list, the selected record is highlighted, and a blue border appears around the list or the form that contains the selected record.
  2. Click Delete.
    A dialog box appears, asking you to confirm the deletion.
  3. Click OK to delete the record.
To delete a record using the menu button
  2. Click the menu button, and then click Delete Record.
To delete a record using the application-level menu
  2. From the application-level menu, choose Edit > Delete Record.
Fundamentals
