Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Default Calendar Activity Durations
Each activity you schedule on your calendar has a default duration. You can determine the default from the User Preferences screen. To set up a default calendar activity duration
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Calendar.
The Calendar form appears.
- Select the desired activity length from the Appointment Duration drop-down list.
