Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Default Participant Availability Subviews
In the Gantt chart in the Participant Availability subview, you can choose to display only your working hours or all 24 hours of the day.
To set up a default participant chart display
  1. From the application-level menu, choose Tools > User Preferences.
    The User Preferences screen appears.
  2. On the link bar, click Calendar.
    The Calendar screen appears.
  3. Choose Working Hours or 24 Hours from the Participant Chart Display drop-down list.
Fundamentals
