Fundamentals > Setting User Preferences >
Setting Time Zone Preferences
You can specify which time zone your Siebel application uses to display date and time fields during your session. To set a default time zone
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Profile.
The Profile form appears.
- In the Time Zone field, click the select button.
The Pick Time Zone dialog box appears.
- Select the desired time zone and click OK.
NOTE: In order for calendar alarms to work correctly, make sure that your computer's time zone setting is the same as the time zone you select in Step 4.
