Fundamentals > Setting User Preferences >
Setting a Startup View
If you want, you can determine which screen and view appears when you launch your Siebel application.
To set a startup view
  1. From the application-level menu, choose Tools > User Preferences.
    The User Preferences screen appears.
  2. On the link bar, click Behavior.
    The Behavior form appears.
  3. In the Startup View field, click the select button.
    The Pick Favorite dialog box appears.
  4. From the Startup View list in the Pick Favorite dialog box, select the screen and view you want to have for your startup view.
    For example, choosing Accounts - Activities will show the Accounts screen > Activities view when you first launch your Siebel application.
  5. Click OK.
    The screen and view you selected appear in the Startup View field.
Fundamentals
