Fundamentals > Sharing Information > Emailing, Faxing, Paging, and Wireless MessagingYou can send email messages, faxes, pages, and wireless messages from within your Siebel application. The record that is active when the Send command is executed determines what information will be sent and what options are available. The following commands are available on the application-level File menu:
You may not have access to send functionality, depending on the configuration of your application. Contact your Siebel administrator for details. Sending a fax, page, or wireless message is similar to sending an email. Choose the appropriate Send command from the application-level File menu. If you cannot send a fax, page, or wireless message, contact your Siebel administrator. Related Topic |
Fundamentals |
