Fundamentals > Using the Calendar >
Adding Activities to the Calendar
You can add an activity to the calendar from the daily, weekly, or monthly view. To add an activity to the calendar
- Navigate to the Calendar screen.
- In the Daily, Weekly, or Monthly view, click New.
If you are in the Weekly or Monthly view, you can first highlight a day by clicking on that day. Then, when you click New, the start time will default to the date that you highlighted.
The Calendar Detail form appears.
- Complete the fields.
- Click Save This One.
The activity appears in your calendar as long as it has a start time. It also appears in your Activities screen.
To type an activity directly in the calendar
- Navigate to the Daily or 5 Day Weekly calendar view.
- Do one of the following:
- In the Daily view, click the area of the calendar where you want to create the activity.
- In the 5 Day Weekly view, click the day and time where you want to create the activity.
- Type a description.
- Click away from the text you typed to create the activity.
