Fundamentals > Using the Calendar >
Marking To Do Activities Complete
To Do activities remain in your To Do list and carry forward to the next day until they are completed. Use the Done check box to mark a To Do as completed. Once an item is marked complete, that item will not appear in the To Do list when the Calendar screen is refreshed. Only uncompleted items appear in the To Do list. To mark a To Do as completed
- Navigate to the Calendar screen.
- In the To Do list, select the To Do item you want to mark as completed.
- Select the Done check box.
