Fundamentals > Using the Calendar >
Rescheduling Activities
In the Daily view or the 5 Day Weekly view of the calendar, you can use drag-and-drop functionality or stretching to reschedule activities. NOTE: You cannot drag appointments across views. For example, you cannot drag an appointment from the Daily view to the Monthly view.
To reschedule an activity using drag-and-drop
- Navigate to the Calendar screen.
- Navigate to the Daily or 5 Day Weekly view.
- Place your cursor over the left edge of the activity.
A cross with arrowheads appears.
- Drag the activity to the new time slot.
To reschedule an activity by stretching it
- To change an activity's start time, place the cursor on the activity's top border, and click and drag the activity's top border to an earlier or later location.
- To change an activity's end time, place the cursor over the activity's bottom border, and click and drag activity's bottom border to an earlier or later location.
