Fundamentals > Using Query to Locate Information >
Deleting Queries
You can delete user-defined queries. To delete a saved query
- Navigate to the desired screen.
- From the application-level menu, choose Query > Delete Saved Query.
The Delete Record dialog box appears, showing the user-defined queries for that screen.
- Select the query you want to delete in the Query Name list.
- Click OK to delete the query.
