Fundamentals > Using Search to Locate Information > About SearchSearch is a text retrieval tool that allows you to perform searches for text within your application and in documents inside and outside your application. Siebel Search Center allows you to search for information and view the results without losing the current data on your screen. You can create searches from anywhere within your Siebel application using the Search Center. For more information about search functionality, see Siebel Search Administration Guide. |
Fundamentals |
