Fundamentals > Using Selection Dialog Boxes > Associating Records Using a Single Selection Dialog BoxDepending on where you are in the Siebel application, you can associate an existing record or a new record in a single selection dialog box. To associate an existing record using a single selection dialog box
To associate a new record using a single selection dialog box
NOTE: There are some situations in which you cannot add new records to single selection dialog boxes. |
Fundamentals |
