Siebel Hospitality Guide > Setting Up Function Spaces, Sleeping Rooms, and Suites >
Associating Setup Styles with Function Space Categories
An administrator can associate setup styles with function space categories.
This task is a step in Process of Setting Up Function Spaces, Sleeping Rooms, and Suites.
To assign a setup style to a function space category
  1. Navigate to the Property Administration screen > Properties list.
  2. In the Properties list, query for the required property.
  3. Click the link in the Property Name field, and then click the Category view tab.
  4. In the Category list, select the category, and then scroll down and click the Setup Style view tab.
  5. In the Setup Style list, create a new record.
  6. Select a value in the Setup Style field.
    You must create a style before you can select a value in this field as described in Creating Property-Specific Setup Styles and Associating Packages.
  7. Complete the remaining fields, specifying the minimum and maximum number of expected attendees for this setup style, and then save the record.
    NOTE:  If a setup style has a package associated with it and that style is associated with the function space category, then the package is also associated with the function space category.
Related Topics
