Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up a Matrix Series >
Updating All Adjustment Amounts of a Series Record
On occasion, an administrator may wish to increase or decrease all the adjustment amounts associated with a matrix series. The administrator can do this using the Transform button.
To increase or decrease all adjustment amounts for a matrix series
  1. Navigate to the Property Pricing Admin screen > Properties list > Matrix Series view tab for the required property record.
  2. Select the required series record, and click Transform. The Matrix Transform dialog box is displayed.
  3. In the Transform field, enter the amount by which the adjustment amounts should be transformed. For example, if you want to increase adjustment amounts by ten percent, enter 110%, or if you want to decrease adjustment amounts by ten percent, enter 90%.
  4. Do one of the following:
    • If you want the adjustment to apply to Price Overrides only, make sure that the Price Override Only check box is selected.
    • If you want the adjustment to apply to all adjustment amounts, make sure that the Price Override Only check box is deselected.
  5. Click Transform. The transformation is applied to the adjustment amount fields for Account and Segment matrices.
