Siebel Hospitality Guide > Setting Up Products and Assets >
Creating Property-Specific Products
Use the Product Administration screen to create property-specific products.
This task is a step in Process of Setting Up Products and Assets.
To create a property-specific product
  1. Navigate to the Administration - Product screen > Products list.
  2. In the Products list, click New and Release to create a new product record.
  3. Complete the appropriate fields and save the record.
    The following table describes some of the fields.
    Field
    Description
    Name
    The product name.
    Part #
    The part number for the product.
    Type
    The type of product. Examples are Menu, Package, Sleeping Room, and Setup Style.
    Organization
    Automatically populated with the name of the default organization. The user can change the selection or add more than one organization, designating one organization as the primary.
    UoM
    The unit of measure used for the product. For example, if coffee is the product, the unit of measure might be pounds.
    Revenue Subcategory
    The revenue subcategory for the product.
    Revenue Category
    This field is automatically populated after a revenue subcategory is specified.
    Revenue Parent Category
    Resource Type
    Designates whether the product is Critical, Non Critical, or General. For more information about these values, see About Hospitality Assets.
    Property
    The property associated with the product.
