Siebel Hospitality Guide > Setting Up Properties >
Creating Addresses for Properties
Before a property record is created, an administrator must define the address for the property.
This task is a step in Process of Setting Up Properties.
To create an address for a property
  1. Navigate to the Administration - Data screen > Zip Code Administration list view.
  2. In the Zip Code Administration list, verify that you enter valid data for all ZIP Codes. For more information about administering ZIP Codes, see Applications Administration Guide.
    NOTE:  If you do not have valid data for ZIP Codes, you will not be able to associate an address with a property.
  3. Navigate to the Administration - Data screen > Addresses list view.
  4. In the Addresses list, create an address record for each property, complete the fields, and save the record.
