Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Managing Functions Associated with Quotes > Preventing Functions from Being MovedWhen defining functions using the Quotes screen's Functions view, a user can prevent other users from moving the function to an alternative function space by using the Do Not Move flag. The Do Not Move Flag check box is cleared by default, which means that other users can typically move functions as required, subject to time and space availability. The Do Not Move Flag check box is only enabled if the reserved primary function space is a specific space. If the booking is for a category, the Do Not Move Flag check box is read-only. If a user tries to change the Function Space value to a category after the Do Not Move check box has been selected, a message is displayed, asking for confirmation. If the user clicks OK, the Do Not Move Flag check box is cleared and the booking is changed to a category. NOTE: The handling of bookings with the Do Not Move flag can vary depending on configuration carried out by the administrator. See Configuring the Do Not Move Flag for more information. In the diary views, bookings that cannot be moved because of this flag are indicated with a padlock icon. Using query assistant, a search can be performed to locate bookings with the Do Not Move flag. This topic is a step in Managing Functions Associated with Quotes. To prevent functions from being moved
Siebel Hospitality Guide |
