Siebel Hospitality Guide > Creating Hospitality Reports > About the Function Space Products Report >
Function Space Product Report Fields
Table 50 lists the fields used in the Function Space Product report's Category section.
Table 50. Function Space Product Report Fields: Category Section
Field
Comments
Source
Function Space Category Name
The function space category defined for the property.
Property Admin > Category
FSC Max
The default maximum value for the category.
FSC Physical Area
The defined physical area for the category.
Property UoM
The Unit of Measure used by the hotel (in square feet or square meters).
FSC Description
The description entered for the category.
FSC Back-Up Required
This field indicates whether backup space is required for the category.
Bypass Fit
This field indicates whether the space is included in the best fit/next fit availability process.
Suite
This field indicates whether this category is of type suite.
Start Date
The date that the category is available for taking bookings.
End Date
The date that the category is no longer part of the inventory.
Table 51 lists the fields used in the Function Space Product report's Specific Space section.
Table 51. Function Space Product Report Fields: Specific Space Section
Field
Comments
Source
Specific Space
The name of the associated specific space.
Property Admin > Specific Space
Description
The description of the specific space.
Type
Indicates whether the specific space is configured or indivisible.
Display Seq.
The specific spaces's sequence number, used to specify the order of display in the property's Function Space Diary.
Usable Area (sq. ft./sq. meter)
The usable area of the specific space. It may be less than the physical area.
Physical Area
The physical area of the specific space.
Property UoM
Floor
The floor number where the specific space is located.
Building
The building where the specific space is located in the property.
Back-up Required
This field indicates whether backup space is required for the specific space.
Bypass Fit
This field indicates whether the specific space is included in the best fit/next fit availability process.
Suite
This field indicates whether this specific space is of type suite.
Start Date
The date that the specific space is available for taking bookings.
End Date
The date that the specific space is no longer part of the inventory.
