Table 1. New Product Features in Siebel Hospitality Guide, Version 7.8
Setting Up Guest Conveniences |
This section details how to add information about guest conveniences, for example, airports and restaurants, that are in close proximity to a property. |
Setting Up Nonparticipating Properties |
This section details how to set up nonparticipating properties, which are properties that do not use the Hospitality Event Sales Execution, Central Reservation System, or Function Space Inventory processes. |
Defining the Property's Neighborhood Characteristics |
This section details how you can add details of the local companies, restaurants, and attractions that are in the property's neighborhood. |
Defining the Property Profile |
This section details how to profile the property. |
Defining Property Policies |
This section details how to add the property's policies to the property record. |
Adding Property Floor Plans |
This section details how to add floor plans to the property record. |
Setting Up Property Clusters |
This section details how to set up clusters of properties. |
Marking a Specific Space as Requiring Backup |
This section details how to indicate whether or not a specific space requires a backup space. |
Configuring the Do Not Move Flag |
This section details how to prevent a function from being moved. |
Adding Catalog Visibility to Products |
This section details how to make catalogs of products visible to employees. |
Forecasting Product Consumption |
This section details how to forecast the consumption levels of a product. |
Adding Product Attributes to Function Spaces, Categories, and Sleeping Rooms |
This section details how function spaces, categories, and sleeping rooms can, as products, have attributes assigned to them. |
Creating Function Space Product Features for the Opportunity Screen's Function Agenda |
This section details how features can be added to products (in this case, specific spaces or categories) so that they can be used in the selection of a space for a function agenda. |
Defining Active and Backup Information |
This section details how active and backup information should be displayed within the Function Space Diary. |
Using the Function Space Calendar |
This section details how to use the function space calendar. |
Using the Sleeping Room Calendar |
This section details how to use the sleeping room calendar. |
Setting Up Minimum and Maximum Controls for Function Spaces, Catering Products, and Sleeping Rooms |
This section details how to set up minimum and maximum pricing controls for function spaces, catering products and sleeping rooms. |
Discount Pricing Administration |
This section provides information about discount pricing in Siebel Hospitality. |
Setting Up Full Day Discounts for Function Spaces |
This section details how to set up full day discounts for function spaces. |
Setting Up Volume Discounts |
This section details how to set up volume discounts for products. |
Setting Up a Matrix Series |
This section details how to set up matrix discounts. |
Defining Event Templates |
This chapter details how to set up templates for event types that occur on a regular basis. |
Post Event and Resume Templates |
This chapter details how to set up postevent and resume templates that enable the event manager to evaluate events. |
Managing Hospitality Accounts and Contacts |
This chapter details how to manage accounts and contacts about whom you store details in Siebel Hospitality. |
Using Rapid Room Block |
This section details how to quickly book room blocks using the Rapid Room Block functionality. |
Copying Room Block Line Items |
This section details how to copy room block line items for an opportunity. |
Using the Property Locator |
This section details how to use the Property Locator to find suitable properties for an event opportunity. |
Using the Property Screen |
This section details how to use the Property screen to evaluate potential properties for an event opportunity. |
Applying an Event Template to an Opportunity |
This section details how to apply an event template to an opportunity. |
Modifying the Opportunity Arrival Date |
This section details how to modify the arrival date for an opportunity. |
Adding Macro Estimates to an Opportunity |
This section details how to add revenue macro estimates to an opportunity. |
Using Quick Opportunity Capture |
This section details how to quickly capture information about an opportunity using the Quick Opportunity Capture functionality. |
About Host-Affiliate Relationships |
This section provides information about host-affiliate relationships and how to develop opportunities for these relationships. |
Using the Opportunity Explorer |
This section details how to use the Opportunity Explorer. |
Using Opportunity Charts |
This section details how to use opportunity charts. |
Managing Recurring Events |
This chapter details how to create recurring events that can occur at one or multiple properties. |
Asynchronous Generation of Multiple Quotes |
This section provides details about the asynchronous generation of multiple quotes. |
Generating Quotes from Recurring Events |
This section details how to generate quotes from recurring events. |
Generating Quotes from Host-Affiliate Opportunities |
This section details how to generate quotes from host-affiliate opportunities. |
Changing the Event and Sales Manager for a Quote |
This section provides information about changing the Event Manager and Sales Manager for a quote. |
Applying a Property-Specific Event Template to a Quote |
This section details how to apply an event template to a property-specific quote. |
Adding Resource Cluster Line Items |
This section details how to add line items from other properties in a particular property's cluster. |
Preventing Functions from Being Moved |
This section details how to prevent functions from being moved. |
Changing Selected Function Spaces with Product Features |
This section details how to changes selected function spaces with Product Features. |
Reviewing the Room Block Summary |
This section details how to review the room block summary for a quote using the Room Block Summary view. |
Reviewing Quote Discounts |
This section details how to review all discounts for a quote. |
Reviewing the Pricing Waterfall for Function Spaces and Sleeping Rooms |
This section provides information about the pricing waterfall for function spaces and sleeping rooms. |
Viewing the Quote Event Calendar |
This section provides information about the Quote Event Calendar. |
Using Quote, Function, and Room Block Charts |
This section details how to use the quote, function and room block charts. |
Management of Functions That Require Backup Space |
This section details how function spaces can be allotted backup spaces and how these backup spaces are managed. |
Reviewing Group Projected and Blocked Availability |
This section details how figures for Group Projected and Blocked Availability can be reviewed using a new view. |
Cluster Booking of Assets |
This section provides information about assets that can be booked from other properties in a particular property's cluster. |
Launching Cluster Booking of Assets |
This section details how to launch cluster booking in Siebel Hospitality. |
Managing Nonparticipating Properties |
This chapter details the entire sales life cycle from opportunity to order for nonparticipating properties. |
Viewing Floor Plans in the Function Space Diary |
This section details how property floor plans can be accessed from the Function Space Diary. |
Querying the Function Space Diary |
This section details the Function Space Diary query assistant, which allows precise booking searches. |
Printing from the Function Space Diary |
This section details how snapshots of the Function Space Diary information can be printed. |
Viewing the Quote Evaluation Response |
This section details how to view the Quote Evaluation Response form. |
Viewing All Line Items for an Order |
This section details how to view all line items for an order. |
Viewing the Total Discount for an Order |
This section details how to view the total discount for an order. |
Viewing the Event Check Associated with an Order |
This section details how to view the event check associated with an order. |
Viewing the BEO Specifications for an Order |
This section details how to view the Banquet Event Order specifications for an order. |
Viewing the Line Item Audit Trail for an Order |
This section details how to view the audit trail for all line items associated with an order. |
Adding Line Items to an Event Check |
This section details how to add line items to an event check after an event has taken place. |
Viewing Billable and Nonbillable Event Check Line Items |
This section details how to view all billable and nonbillable line items associated with an event check. |
Configuring Reports |
This section details how the report headers can be set up and configured for the various reports. |
About the Banquet Revenue Summary Report |
This section describes the Banquet Revenue Summary report. |
About the Function Space Products Report |
This section describes the Function Space Products report. |
About the Function Space Setup Style Report |
This section describes the Function Space Setup Style report. |
About the Diary Report |
This section describes the Diary report. |
About the FSI New Bookings Report |
This section describes the FSI New Bookings report. |
