Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment > Custom Extensions to the Siebel Schema > Storage Control File Object Definitions for New Schema ObjectsIf you define a new table in Siebel Tools (for example, if you add a new extension table), you must add the table object definition to your storage control file to place the table in the appropriate table space. For example, if you create a new extension table called X_EXTENT, you must create a corresponding object definition in the storage control file: [Object 6001] NOTE: If you have different storage control files for your development environment and production environment, you must add the new table object definition to both storage control files. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
