Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment >
Spooling DDL Generated by the Apply Button
The Siebel environment variable, SIEBEL_GENERATE_DDL, allows you to record into a file the DDL that is generated when you click the Apply button in Siebel Tools. To spool DDL, generated by clicking the Apply button, into a file
- Set the environment variable before running Siebel Tools on Windows from the command line or using Windows environment parameters:
- If using the command line, set
SIEBEL_GENERATE_DDL=Y.
- If using the Windows environment parameters, do the following:
- From the Start menu, navigate to Settings > Control Panel > System.
- Click the Advanced tab, and click Environment Variables.
- In the System Variables box, click New.
- The New System Variable window appears.
- Enter
SIEBEL_GENERATE_DDL in the Variable name field and Y in the Variable value field, and click OK.
- Continue to click OK until you are out of the System Variable window.
- Open Siebel Tools, and click the Apply button.
The DDL is generated to the file output.sql, which is found in the SIEBEL_ROOT\bin directory (Windows) or the $SIEBEL_ROOT /bin directory (UNIX), where SIEBEL_ROOT is the directory where Siebel Tools is installed.
