Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment > Process of Applying Schema Extensions to the Target Database >
Applying Schema Changes to the Target Database
After generating the DDL into files, you must use Siebel-provided scripts, your own FTP, or a similar file transfer program to transport the DDL files to the zSeries machine, where you execute it using customary methods, for example, SPUFI. To apply schema changes to the target database using Siebel scripts
- Navigate to the output directory (
DBSRVR_ROOT \db2390 under Windows or $DBSRVR_ROOT /db2390 under UNIX) and open the ftpsync.txt file.
- Edit the ftpsync.txt file using the following information:
- Change
&IP to the IP address of your DB2 host, for example ZM01 .
- Change
&Username to your own user name, for example SADMIN .
- Change all occurrences of
SIEBELQ1 to your own high-level qualifier (HLQ ), for example, SADMIN . Save the file.
The following is an example of the ftpsync.txt file:
open &IP
user &Username
quote site cylinders primary=1 secondary=1 quote site recfm=fb lrecl=80 blksize=0
quote site cylinders primary=1 secondary=1 send &directoryPath1/jobsync.txt 'HLQ .SIEBEL.V00'
quote site cylinders primary=10 secondary=2 send &directoryPath1/unload.ldc 'HLQ .SIEBEL.V01'
quote site cylinders primary=10 secondary=2 send &directoryPath1/load.ldc 'HLQ .SIEBEL.V02'
quote site cylinders primary=5 secondary=2 send &directoryPath1/schema.sql 'HLQ .SIEBEL.V03'
quote site cylinders primary=1 secondary=1 send &directoryPath1/bumpver.sql 'HLQ .SIEBEL.V04'
- Execute ftpsync.txt
and send the file to the host.
From the command line enter:
ftp -vn < ftpsync.txt > ftpsync.log
- Enter the password associated with the user name you specified in the ftpsync.txt file.
Press any key to continue.
- The log file ftpsync.log is created in the
DBSRVR_ROOT \db2390 (Windows) or $DBSRVR_ROOT/db2390 (UNIX) directory.
The log contains information on the file transfer.
- When the transfer is successfully completed, log on to the mainframe, and edit the
HLQ .SIEBEL.V00D2P data set by changing the job card and HLQ.
- Submit the job and, when it is completed, make sure that the return code is 0.
A new partitioned data set (PDS) is created, HLQ .SIEBEL.D2P.EXEC.
- Execute the following REXX exec to apply the DDL generated for the schema migration process.
Execute clist HLQ .SIEBEL.D2P.EXEC(SBLD2P)
- Verify the schema changes.
